1st gen tacoma rear shocks
Hey everyone! Doing a toytec coilover front adjustable lift kit to level out my dad's 2002 tacoma x-cab trd 4x4 5 speed. We just want to level the front out to the rear and are trying to find a proper shock. I want a bilstein 5 series (5100 or 5125) but I notice that people have trouble bottoming out the shocks before they hit the bump stop. Since that is sometimes the case I went out to wheeler's offroad and found online the specs they list for their rear 5125 kit. These are the specs for the short and long shock respectively.
short
Brand:Bilstein
Manufacturer's Part Number: 33-185590
Product Line:Bilstein 5125 Series Shocks
Summit Racing Part Number:BSN-33-185590
Internal Design: Monotube
Gas Charged: Yes
Extended Length (in): 21.540 in.
Collapsed Length (in): 13.580 in.
Upper Mount: Eyelet
Lower Mount: Eyelet
Quantity: Sold individually.
Notes: Zinc plated. 8.130 inch travel 255/70 valving.
long
Brand:Bilstein
Manufacturer's Part Number: 33-185606
Product Line:Bilstein 5100 Series Shocks
Summit Racing Part Number:BSN-33-185606
Extended Length (in): 22.500 in.
Collapsed Length (in): 14.060 in.
Bushing Material: Rubber
Upper Mount: Eyelet
Lower Mount: Eyelet
Notes: 255/70 valving, 8.60 in. travel.
Some people say they have issues with the shock bottoming out before the bump stop is it. So i went ahead and cross referenced some stock height shocks and found the numbers for ranchos.
rancho short
Compressed Length: 13.070
Extended Length: 20.320
Travel Length: 7.250
rancho long
Compressed Length: 13.630
Extended Length: 21.450
Travel Length: 7.820
Looking at these numbers, I notice that the short bilstein measurement wise is the same as the long rancho. So i figured, if i could find a bilstein 5125 that matched the short rancho then maybe i would have a kit that would not bottom out early. I found this 5125 shock
short proposal
Brand:Bilstein
Manufacturer's Part Number: 33-233970
Part Type:Shocks and Struts
Summit Racing Part Number:BSN-33233970
UPC: 651860729398
Adjustable: No
Gas Charged: Yes
Extended Length (in): 20.380 in.
Collapsed Length (in): 13.040 in.
Body Diameter (in): 1.811 in.
Upper Mount: Eyelet
Lower Mount: Eyelet
Notes: Zinc plated. 7.30 inch travel 255/70 valving.
long proposal
Brand:Bilstein
Upper Mount: Eyelet
Lower Mount: Eyelet
This shock seems to be exactly the same specs as the short rancho. If this is the case, then it would seem better to run these two 5125 shocks on a stock height vehicle, ans then maybe I can avoid bottoming out the shock before I hit the bump stop? Questions, comments, and criticisms welcomed!
short
Brand:Bilstein
Gas Charged: Yes
Upper Mount: Eyelet
Lower Mount: Eyelet
long
Brand:Bilstein
Upper Mount: Eyelet
Lower Mount: Eyelet
rancho short
rancho long
short proposal
Brand:Bilstein
UPC: 651860729398
Adjustable: No
Gas Charged: Yes
Upper Mount: Eyelet
Lower Mount: Eyelet
long proposal
Brand:Bilstein
Upper Mount: Eyelet
Lower Mount: Eyelet
