1994 toyota xcab front hub/wheel bearing bad
My son has a 1994 xcab he left a front hub locked in.anyway the bearings went dry and now he needs a new hub and bearings or something like this.im not that mechanical.whatever the assembly is oreillys does not sell.they said we would have to find a used one.what vehicle has the same setup?forerunner same year?
Hey thanks. I'm in tennessee .at work all weekend so I haven't seen the truck but his grandad got someone he knows to work on it.what ever he said it was bad up to the spindle?
4runner of same year and drivetrain (4wd) should be the same.
I know you said he left a hub locked in, so I presume it has Aisin manual hubs? Not the ADD(auto differential disconnect[?])? And leaving a hub locked shouldn't cause that severe of a problem. Although it will create more heat, which may have caused the bearing to overheat and fail, if the grease was in bad shape to begin with or non-existent.
Crazy_Guy97
12
06-24-2015 04:02 PM
