WTB[NorAtl]: Intake Manifold Sensor
22RE Intake Manifold Sensor
Hi,
Did the EGR delete on my truck and somehow misplaced the sensor. I need it to solder in a 10k resistor which will turn off my Check Engine Light. I want to be able to plug right into the connector on the engine harness. Sensor in question is the white one in the picture. I don't even need the actual sensor if someone wants to cut the wires off a parts truck. Just need the connector.
Why don't you get a couple of those quick wire couplers cut it off before the connector solder your resistor inbetween 2 couplers and plug it in and if you ever want to go back just plug the connector back in and pull the sheath over the couplers
The connector in question is
that is for air conditioning and also for the power steering it isnt a connector that has to be connected . I dont remember where I read this info I am posting but i do know that it is confirmed good luck hope this helps you 👍
ksmudrunner99
08-07-2015 06:46 PM
