v8 Ltd. 4Runner have tranny cooler?
Does anybody know if the 2004 V8 Limited 4Runner come with a tranny cooler if it has the factory tow package? (I couldn't find it on any searches)
Cheers
Cheers
trans cooler
i'm sure that it does. it's incorporated into the radiator. my 2003 V6 Ltd. has this setup so I'm sure your'e V8 has it as well.
Look at your radiator on the bottom backside (below the fan), there should be 2 smaller hoses, follow them back to the tranny. my advice to you is run a tranny cooler in conjuction (inline) with the the stock cooler. I also added a remote filter as well. I use a huge K&N filter to hold extra tranny fluid. with this setup, my trans holds an extra 2 quarts of fluid. temp is around 190 when towing my boat.
Thanks for the replys, Cheers.
I Just bought a 2004 4Runner Limited V8 and it has a trans. cooler thats seperate from the radiator, I have a B&M Super Cooler that I'm thinking of installing...........so in answering your question I belive that your 4runner v8 has the same set up as mine.
BeMiceElf
10-10-2015 09:40 PM
Iceman4193
07-15-2015 04:48 PM
madxman21
07-09-2015 10:26 AM
Jnkml
07-06-2015 01:20 PM
