Tire pressure warning light problem?
Old 12-16-2006 | 07:30 AM
highway74's Avatar
The low tire pressure warning light on my wife's 4th gen limited stays on continuously. Tire pressure checks out per factory on all 4. Does this light double as a service reminder? Any ideas?
Old 12-16-2006 | 08:21 AM
highway74's Avatar
Tires
Figured out the problem, spare was down to 25psi, filled it up to 32 psi, light goes off.
Old 12-17-2006 | 06:10 AM
Sharp4runr's Avatar
Here is a lot of info on the TPS system by way of a TSB: http://www.alldata.com/tsb/Toyota/11...-06/index.html
Old 12-30-2006 | 09:45 AM
highway74's Avatar
Cool, thanks for the reply.
Old 04-05-2007 | 10:40 AM
jmh94's Avatar
How does the tire pressure warning light work?
I don't understand how it can sense the pressure in the spare tire.
How does the car sense the pressure in the 4 actual tires as well?
Old 04-05-2007 | 10:41 AM
mastacox's Avatar
Each rim has a pressure sensor mounted in the tire, which x-mits to the computer. People have had the same problem if they remove the spare from the vehicle IIRC.
Old 04-12-2007 | 08:08 AM
BlakeTTS's Avatar
Ive tried everything to get the darn light to turn back off. All 5 tires have been checked, and everything is within specs. Does anyone know if they are covered under warranty if I cant get the thing to turn off?
Old 04-12-2007 | 08:26 AM
NaeSLaS's Avatar
do these actually have pressure sensors? Every other tire pressure system i've seen monitors the individual wheel speed (from the ABS system) and activates the light with rotational speed differences.
if it has a remote pressure sensor in the tire, wouldn't it have a transmitter, and thus a battery? maybe a dead battery?
Old 04-13-2007 | 06:57 AM
BlakeTTS's Avatar
Is that your WRX in your profile? I just traded my bug eye for my 4runner. I have to say, I dont miss it at all.
Old 04-13-2007 | 07:08 AM
NaeSLaS's Avatar
no, as funny as it is, it's my mom's WRX, that i upgrade/tool on. my ride is the 94 legacy, which is sold, pending myself getting a truck.
it's so funny to see your mom stomp a ricer on the street.
Old 04-13-2007 | 07:15 AM
BlakeTTS's Avatar
I see you have the side skirts with it, and looks like stock rims? I did love mine for a while, but started to have too many problems with all the "stomping" going on. I had a great Injen intake on it with strut bars and prodrive cat back. I'll try to post a pic of it. They are fun to tool around with. Do you have suspension on there? Cause if not, a cheap way to get great handling is to put on Strut and sway bars. Couldnt believe the results I got with them. If you didnt want to drop the car that is...
06-01-2021 01:51 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
colinmil
07-06-2015 04:03 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Tire pressure warning light problem?
