Low Beam Headlight Problem / DRL?
Old 02-14-2009 | 09:47 AM
beardman's Avatar
I have an 03 4Runner with DRL's, the low beams have recently stopped working. The DRL's and the high beams both continue to work (both when on and when the stalk is pulled all the way forward) The interior lights do go one when the headlight switched in put in the on position.
I have tried:
1. Jumping the main headlight relay.
2. Testing the switch; Continuity across pins 16, 14 & 13 (I do not have continuity across pins 16 & 12 though which are labeled as having such when the switch is in Auto)
3. Checking all of the fuses.
Could this have anything to do with DRL system? or is that completely independent?
Is there any way for me to confirm that this is not the switch by bypassing/jumping it?
I have attached the page I have been using for reference.
Any help is appreciated.
Attached Thumbnails Low Beam Headlight Problem / DRL?-inspec40.jpg
Old 02-14-2009 | 10:01 AM
4Crawler's Avatar
Are the DRLs the (dimmed) high beams or the low beams?
Old 02-14-2009 | 01:04 PM
beardman's Avatar
DRL's
The DRL's are the indicator Lamps. Not the Headlights.
Old 02-14-2009 | 01:26 PM
4Crawler's Avatar
Well then, have you checked the obvious? That is the bulbs or low beam filaments?
Old 02-14-2009 | 02:33 PM
beardman's Avatar
Check
Yep, checked those too.
Old 03-11-2009 | 02:25 PM
beardman's Avatar
Crazy?
Okay, Now I am going crazy.
I have replaced the DRL relay, tried a replacement headlight switch, jumped the headlight relay in the fuse box under the hood, triple checked the fuses, triple checked the bulbs themselves.
What am I missing here?
Any help is appreciated in keeping me sane!!
Joel
jbv808
08-06-2021 04:47 PM
Sleaker
08-26-2020 06:03 AM
rushw
07-18-2015 01:46 PM
kyletbert
07-17-2015 11:39 AM
icentropy
07-14-2015 10:23 AM
Quick Reply: Low Beam Headlight Problem / DRL?
