Hub Centric or Lug Centric?
Likely lug centric, but the easy way to tell is look closely where the wheel meets the hub. If you see a gap between the wheel center hole and the hub, then the hub is not centering the wheel.
On my '85 4Runner, there is at least a 1/8" gap all the way around between the hub and the wheel. And when you put the wheel on the hub, you need to lift it up and align the lug holes with the studs. So the lug studs and nuts both center the wheel and hold it to the hub.
On my VW, you can put the wheel onto the hub and it slips over a centering ring and will sit there without any of the lug bolts installed. In fact you put the wheel on like that and then you thread each lug bolt into place, so all the lug bolts do is hold the wheel to the hub, it is already centered.
HiLuxer
01-06-2016 11:34 AM
Cycles
09-29-2015 06:37 AM
Toys4parts
09-26-2015 01:56 PM
sonorn67
09-19-2015 05:39 PM
