Hi-Lift w/stock 4Runner
Old 09-23-2008 | 10:47 PM
Will_4R's Avatar
Hi-Lift w/stock 4Runner?
Can I use a Hi-Lift with a stock 4Runner, or do I need to have bumper or rock sliders to provide purchase for the jack?
Old 09-24-2008 | 03:01 AM
crolison's Avatar
You can use it on your trailer hitch, and thats about it, unless you wanna seriously dent something up.
Old 09-24-2008 | 04:37 AM
waskillywabbit's Avatar
Round tube sliders or bumpers. Trailer hitch only takes care of the rear and leaves the front grounded. If you wheel, a Hi-Lift is required equipment.
Old 09-24-2008 | 06:07 AM
netwt12's Avatar
so are sliders.
Old 09-24-2008 | 06:10 AM
littlecommando's Avatar
can you use on 1st gen front bumpers or where the tow hook ataches?
Old 09-24-2008 | 06:33 AM
Will_4R's Avatar
Thanks for the replies guys. I guess I should add sliders. I am also thinking about the ARB bumper, but might wait on that since it is expensive, and I am worried about the added weight up front with stock springs.
Old 09-24-2008 | 10:15 AM
Matt16's Avatar
to change a tire like this, you need a jackstand.
Old 09-29-2008 | 07:53 PM
colsoncj's Avatar
sliders are the best way to go in my opinion...
hey brian, why are hi-lifts required for wheelin? Have I been doin it all wrong?
Old 09-29-2008 | 08:34 PM
strykersd's Avatar
This should work on your stock bumpers
http://www.hi-lift.com/accessories/bumper-lift.html
Old 09-29-2008 | 09:07 PM
Will_4R's Avatar
I don't think that would work with my plastic bumpers. Actually, I am pretty sure it would just tare the bumper off. It seems like rock sliders would be a good investment if they can definately make for good jack points. Is it possible to lift only one corner off the ground using a slider as the jack point, or will it always lift up the whole side?
Old 09-29-2008 | 09:30 PM
d0ubledown's Avatar
depending on where youre jacking from, it can do either or. when i rotated my runner, i put the hi-lift in the middle of the tires, and the whole side came off. of course there was more flex in them than lifting off the fr/rr corner...but it held the weight of the truck just fine.
talk to taran over at bigcountrycustoms.com he'll hook you up with trail gear sliders..he did mine for just under or around 3 bills installed....
Old 09-29-2008 | 10:42 PM
strykersd's Avatar
Oh sorry, I didn't see you had a newer model
Old 11-08-2008 | 08:56 AM
Will_4R's Avatar
Do I need a special attachement for the Hi-Lift to use it on rock sliders?
Old 11-08-2008 | 09:20 AM
http://www.wabfab.org/products/slide...eradapters.htm
Old 11-08-2008 | 10:12 AM
86tuning's Avatar
That thing works like a hot dayam. I used a highlift to jack up the nose of a unimog to reseat the spring, and I didn't need to take the slider adapter off.
Thanks wabfab. Nice product.
Flying91
45
04-11-2024 04:39 PM
icentropy
09-16-2020 02:47 PM
BeMiceElf
10-10-2015 09:40 PM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: Hi-Lift w/stock 4Runner
