Last edit by: IB Advertising
- Toyota Tacoma How to Replace Dash and Center Console Lights<br>Step by step instructions for do-it-yourself repairs.
Climate Control Dash Light Replacement
My wife's 05 4runner SR5 has a light out on the display that shows the inside/outside temperature (just below the radio). It is actually the backlight that is out because it looks fine during the day. At night the screen is blank. The other thing is that it is only affects the passenger side of the display, the driver's side is fine.
Does anyone know if this is as simple as a bulb that is out or is it an LED display issue? I don't want to take it to the stealership if I don't have too since it is out of warranty. Any help is appreciated.
From: Yotatech, because Pirate is too expensive. NorCal.
Not many people here work on stuff that new. But it shouldnt be that hard to take apart the dash and figure out what bulb is out.
Either that or just call the parts deparment at Toyota and tell them your problem they will probably be able to get you the specific bulb and you can just replace it yourself.
I may just have to dive in and take the dash apart. I 'd rather not tear it apart too much without some idea of what I'll find since it is my wife's truck (that could start more problems than anyone wants!). The local dealership is not so bright. If there isn't a code they can't seem to fix anything. I could just bite my lip and call 'em, I haven't hung up on them in a while.
This may be similar to the 3rd gens digital climate display which have removeable bulbs. Looking at the 05 parts diagram there are two bulbs back there. I am not sure on removal and etc but the prt. number I see is 90010-09017
You should check out http://www.toyota-4runner.org/ since it is geared around the 4th gen.
Thanks for the input, I'll let you know how it works out.
You owe me a beer;
http://www.toyota120.com/html/center...le_lights.html
Ive never had a problem with the dealership not being too bright. But I kinda know all the guys there. My dad worked toyota parts for 17 years and we still go to a guy that worked there before he did. I beleive hes been there over 30 years now. But then again Ive never had a problem with the Toyota guys at any other dealership.
I will say this about Toyota though, and I'd like to know if anyone else has experienced this...we paid to have the first fuel pump fixed with an independent mechanic (we didn't know it was under the powertrain warranty). When that pump burned up we went to the dealer and they fixed it under warranty. We then called Toyota directly (not the dealership, the mfg.), explained what happened and sent in a copy of the bill for the first pump...A month or so later Toyota sent us a check for the amount of the repair we paid out of pocket since it should have been covered by warranty!
Ya thats what happens when you call Toyota Corp. If you ever have problems with the dealership call corp. they really hate it when dealers are rude or wrong. They will definetly straighten them out and you will get your stuff done right without further hassle.
Just a follow up. The link above worked great and this was a VERY simple fix. Literally, it took less than 2 minutes. The bulb that was out on mine was a different number than the ones listed on the link. If you pull it out and run up to the toyota parts desk, they can find it on a diagram. Thanks for the help guys...my wife no longer wants to trade her 4runner in anymore...
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
