Which Circuit for Dual Battery?
Hello,
I'd like to install a 2nd battery in my 2014 Tacoma Double Cab 4WD. I'm going to use a relay to connect positive terminal of the aux battery to charging system. Ideally, I want the relay to only be energized when the ignition switch is in the RUN position. (Although I understand it might be necessary for the relay to be energized when the ignition switch is in the ACC position.)
I'm planning to use one of the "Add a Circuit" products to create a power lead for the relay.
Does anyone know which circuit, preferably located in the engine compartment fuse box would be best to piggyback to?
Thanks so much.
AK
Thanks so much.
AK
justdifferentials
Just Differentials
06-13-2022 07:40 PM
runnermedic
13
09-21-2015 05:20 PM
sonorn67
09-19-2015 05:39 PM
