Can't get into 4Lo
Old 12-24-2008 | 06:47 PM
DIHOWARD's Avatar
Can't get into 4Lo
I've tried to get into 4Lo without the light flashing and beeping. What am I doing wrong
foot on the brake
trans in Nuetral.
still beeps, do I need to lock the differential?
Manual says if It dosen't go, see a dealer, GREAT !
Old 12-25-2008 | 04:44 PM
CJ3Flyr's Avatar
foot on the brake
trans in Nuetral.
Put it in 4hi first. Let it fully engage (no flashing lights). Next stop, place it N and try for 4lo.
Old 12-26-2008 | 06:41 AM
AppleJack's Avatar
If that doesn't work, make sure the wheels are straight and roll it fwrd and bkwrd a little, eventually it will go in. I know some folks are really having some trouble getting into Lo. When I first got my Taco, I had some trouble myself, but if you use Lo a lot, I think it gets used to shifting into Lo, and gets easier.
Old 12-26-2008 | 12:25 PM
DIHOWARD's Avatar
I tried the first suggestion, did not work, I'll try the back and forth like it says in the manual, see if that works. will severe cold have anything to do with it? it's been single digit cold for the last few days but warmer today. I have my fingers crossed.
Old 12-26-2008 | 06:47 PM
caturi's Avatar
youre just turning the nob, not pushing the nob, you have to put it in N then push the nob and turn it to 4lo, that will do it
Old 12-26-2008 | 11:50 PM
DIHOWARD's Avatar
I'll give it a try
Old 12-26-2008 | 11:52 PM
Kiroshu's Avatar
Yea pull off a bit in 4hi and use it a min or too then try 4lo
Old 12-28-2008 | 06:35 AM
DIHOWARD's Avatar
Question
I've been using 4Hi all week long and still wont go. yes I pushed in the knob, you have to, to get it to even turn to 4Lo. I think I'll head over to a dealer to see if they can do it. maybe there's a TSB for this. even the manual says to see a dealer if it wont go. maybe there's already a fix for the problem.
Sr5crawler
07-31-2015 12:32 PM
XtraSlow_XtraCab
02-24-2009 03:44 PM
mmcpeck
08-31-2008 06:05 AM
89silverpu
01-23-2008 11:14 AM
GSGALLANT
07-24-2006 09:53 PM
Quick Reply: Can't get into 4Lo
