4th gen. Tire pressure sensor
SO I got the new 2004 4runner. And the new 4runner has these new tire pressure sensors. I wan to add the sensors to the new rims and tires.
The problem that i'm running into, from what i understand, is that the valve stem is connected to a sensor inside of the rims. No I've heard 3 different stories.
1) the valve stems and sensors will not fit the new 20"
2) If I put on the new rims without the sensors my tire pressure light will never come off my dash.
3)or, from a toyota tech, that the sensors in the new rims will throw off the speed sensors and the tire pressure sensor and my truck will be all out of wack.
Can any here help me clarify which is true if any before I replace these rims on Wednesday.
I know many of you have limiteds and have had these sensors for a while. Alos many of you have changed your rims or lifted your truck, what did you experience?
djpg2000
11-11-2020 04:56 AM
09-04-2015 09:27 AM
88yodabasket
07-13-2015 01:32 PM
skoti89
07-08-2015 12:05 AM
