4th Gen 'Runner Max Floor Load Length?
Can someone save me a trip to the dealer? With 2nd (and 3rd if applicable) row seats folded down, what's the floor load length for cargo, etc. with the liftgate closed? TIA...
You can get approx 6' in length (above the folded up rear seat bottoms... or if you remove the seat bottom completely and just fold down the seat back). There is a nice easy mod you can do to your seat bolts to do this quickly if needed.
With the seat bottom just folded up and the seat back folded down, right at floor level, "Will 4R's" number above sounds about right.
I measured one at the dealership. Being conservative, it was from the closed liftgate to the folded seat cushion. It was 66". With the seat cushion removed (two bolts), it gained 3" to 69" total. Between wheel wells is 41".
Compared to FJ it's the same width but 12" longer with seat cushions removed on both rigs. The 'Runner, however, has a completely flat floor vs. FJ. I'll be getting a set of the FJ quick disco rear seat cushion knobs for the new 4R.
FS[SouthCent]: 03-09 4th G 4runner, GX470, FJ Cruiser front Upper Control Arm Ball Joints Sankei 555
ranma21
06-22-2015 11:55 AM
