*4th GEN OLD MAN EMU SUSPENSION LIFT*
Old 05-02-2005 | 06:00 PM
  #81
Good Times's Avatar
swaybar hitting the coils? huh? ya got some photos of this? I'm suspecting you're talking about the uca hitting the coils no?
Old 05-02-2005 | 06:29 PM
  #82
Rishi's Avatar
What's that brown mark on the spring, just above the sway bar, in your front coilover picture.
Old 05-02-2005 | 06:32 PM
  #83
r0cky's Avatar
It is probably mud, reflection, or a scuff from the installation process.
Old 05-02-2005 | 06:43 PM
  #84
FirstToy's Avatar
Yeah it's either a, b or c.
  #85
Rishi's Avatar
This is the stock coilover clearance with sway bar, when the steering is fully turned, and the wheel has full downward droop. Just wondering if it can be an issue with either with OME or other coilover or spacer based lift.
Old 05-02-2005 | 06:47 PM
  #86
r0cky's Avatar
I ran 4.5" with spacers and never once had a problem with that. Similarly, I don't have any problem with it with the SAWs I'm running now.
Old 05-02-2005 | 07:40 PM
  #87
Rishi's Avatar
Could you break up the 4.5" lift into preload and topout e.g. like 3" preload + 1.5" topout. I'm afraid that if the topout exceeds 1.5 to 2" then the spring might touch the sway bar (due to the small available clearance as shown in my picture).
Old 05-02-2005 | 08:03 PM
  #88
r0cky's Avatar
Okay, the preload was around 2+", and the topout was around .75". Something like that, anyway.
Regardless, the Daystar kit uses a larger topout and those running it have not had any issue with the spring touching the sway bar. I don't think that the sway bar or the coil setup move enough to make it an issue.
Old 05-02-2005 | 10:14 PM
  #89
bulldog-yota's Avatar
The swaybar can't touch the strut without something going seriously wrong. The swaybar is also the thing that limts side to side flex (rock crawling), but not up and down as jumping a dune (read DOnahoe and SAW stuff here). Edit the swayar has a solid link to the spindle and the strut doesn't ever turn no matter what your wheels does.
WHat will hit is your UCA. Daysatr uses a 1" topout spacer which is the max and even then there is a slight touch of the UCA and the coil, pending on how your coil is positioned.
AT the moment the only way to get max side to side flex is taking the swaybar out, like Lance did. However I did it and found my on road handling unacceptable for me on the stock Daystar/XREAS combo.
OK now back to topic. I have my rear all sorted out now and can't wait to go hit some trails and see how it flexes, hopefully this weekend. Tehn I can see how she does with the OME kit on.
Old 05-02-2005 | 10:25 PM
  #90
Hey Rishi, like I said before web wheelingis fun and all, but why dont you join me at Hollister. You can look at the sliders, OMEs and can we do some wheeling and you can see what the 4Runner suspensions does. This will give you a far better idea of what you are looking for man.
See
https://www.yotatech.com/forums/show...726#post596726
Old 05-03-2005 | 10:22 AM
  #91
mac4runner's Avatar
Can you enlighten the rest of us?
Old 05-03-2005 | 03:05 PM
  #92
Yeah I had a couple of installation problems with the rear, which I had to sort out with Slee. It is nothing to do with the components themselves (coils and shocks), but rather just installation issues.
SOme where more my imagination than a real issue, but it is all sorted out now and Slee knows all about it ( I think ARB as well). No real point in going through the details as nobody else should experience these issues, and I can also avoid looking like the idiot I am for imagining problems. Well at least all for a good cause so you wont have to go through the same pain!
Old 05-03-2005 | 04:29 PM
  #93
r0cky's Avatar
But some of us aren't ordering from Slee ... and if there are issues, by telling us, we can try to avoid them, or at least recognize "hey, this must've been what Andries was talking about, and he was able to find a way past it" ...
Old 05-27-2005 | 02:45 PM
  #94
4runnerkid88's Avatar
im a newbie i just got my 4runner n love it! i've gone offroad some in the country in concord,nc. i live in charlotte,nc so during the week i drive on the streets n on the weekends go different places with my friends in their jeeps, trucks, 4runners. anyways i want a lift that isnt like 3inchs but sumthin like 1.5-2.5, wut do yall suggest is the best buy. i dont know which to chose cuze i like revtek alot but daystar seems good n i know ome is awesome but i dont know much bout cornfed. i want to run 31inch to 32 inch tires. info would be great! also thinkin bout some exhaust(info on that is welcome)
Old 05-27-2005 | 02:56 PM
  #95
r0cky's Avatar
if you just want 1.5-2.5" of lift, go with Daystar.
Old 05-30-2005 | 08:42 PM
  #96
thanx rocky! also do u know anythin bout the donahoe racing coil racing shocks?if so do they get in the way if i get a daystar lift? donahoe
Old 05-30-2005 | 08:45 PM
  #97
r0cky's Avatar
I think RL Lemke has the Donahoe coilovers ... last I heard, he loved them as well. However, as I understand it, you don't want to use spacers with coilovers ... just one or the other.
Old 05-30-2005 | 09:59 PM
  #98
thanx yea i don tknow which to chose! pics of RL Lemke 4runner in action would be great! also could u tell me how the ride is off n on the road. pics n info would be great!
Old 05-30-2005 | 10:02 PM
  #99
r0cky's Avatar
I don't have any pics of mine. The ride is farrrrrr better with the coilovers than with ANY spacer kit I ran. I think RL would agree. The reason I chose the SAWs was because they were a bit less expensive, and more than good enough for me.
Old 05-30-2005 | 10:07 PM
  #100
where did u buy ur SAWs at?
Quick Reply: *4th GEN OLD MAN EMU SUSPENSION LIFT*
