07 yota low lock ??????
Old 08-23-2009 | 05:56 PM
stony's Avatar
Question 07 yota low lock ??????
nephew, has a 07 yota that won't go into low lock . but it work's in high what could be wrong ???
Old 08-24-2009 | 05:05 AM
William's Avatar
You mean low range? And does it have an automatic transmission?
Here's how I have to do it with mine, which has an automatic transmission:
First, you have to make sure the truck is sitting still. Then, while holding the truck still with the brakes, put the transmission in neutral. Then it should shift into low range just fine.
Going back into high range requires the same technique.
If anything (such as the transmission being in gear) is not in order, there will be a warning beep. If you hear the beep, put it back in high range, correct what needs to be corrected (such as putting the transmission in neutral), then try again.
westonian18
05-01-2020 06:38 AM
shisha1999
09-20-2015 11:44 AM
Athansinis
07-27-2015 08:38 AM
TDonkey
07-26-2015 10:14 AM
Quick Reply: 07 yota low lock ??????
