05 Taco glove box will not open... help
So, I had an annoying glove box rattle at the lever so I went to the dealer and bought a new one and replaced it ($20)... no more rattle. Problem is that now after a while I tried to open the glove box... not working. There is a metal actuator rod that connects the lever to the latch and it has obviously come loose inside.
:confused:
Has anyone else dealt with this and if so, how do you open the glove box or get at this to fix it???
Thanks in advance!
:confused:
Thanks in advance!
well you most likely will need to find a new way in. I don't know how hard it would be to maybe remove some panels to squeeze in behind the lock to maybe manually unlock it.
Re-visiting this with the answer: a big hole saw, cut my way into the face of the glovebox (careful) so I could get my hand and a stubby phillips in there... reach the two screws that hold the latch together on the inside and presto! Latch comes off, old glovebox in the trash and new/used glovebox goes in.
Messy, brutal, but it worked
I was going to suggest a hammer... but I suppose that works too, lol
I beat the glove box into submission in a VW Jetta last week at work to get it open... good stress relief only downside was that it was a VW so it only took 2 good whacks and it shattered, LOL
I've had no issues with the latch on my 06, however that stupid slower-downer detent spring loaded thingy on the right is about the stupidest thing ever... mine found it's way into the trash about a week after I got the truck...
kawazx636
10-06-2021 03:03 PM
83yotastockR
11
11-10-2015 06:54 AM
hiluxinargentina
09-30-2015 05:51 PM
Toys4parts
09-26-2015 01:56 PM
