Would bigger wheel cylinder bore cause more rear braking?
Hey guys im rebuilding the rear drum brakes on a 89 v6 pickup. The rear wheel cylinders were both different sizes. Im guessing previous owner accidentally miss matched the rear cylinders. Now im not sure which bore size it originally had.
single rear tire and the vin says 1/2 ton.
it has F18Q front calipers and its an extra cab
Based on this info from rock auto im leaning on getting the bigger bore.
Would a slightly bigger rear bore cause any issue?
Would the rear grab more than the front?
I’m not sure but i would guess that if the cylinder is larger in volume and the master is pushing the same amount of fluid, there would be less movement at the wheel cyl.
The following users liked this post:
old87yota (10-01-2024)
YT Community Team
I'd think it'd be easier to just get the size that Toyota matched with the existing system. That way you don't have to worry about the master cylinder being under-sized, or making any adjustments to the proportioning valve. The vast majority of the actual braking is the responsibility of the front brakes. The rear brakes just makes sure the back of your vehicle doesn't try to pass up the front when braking, especially in turns.
Jose Pena (10-01-2024)
thewanderlustking
02-25-2022 08:48 PM
richardashe
08-18-2021 02:04 AM
