Works for a While, Then Shuts Down
Okay so a fire happened (unrelated to me or the truck) not a real big thing but my truck is covered in gas at the moment so I was like "f- this" and just used the starter to back it out of the way. It picked up and the engine backed it the rest of the way. I looked into it, and my float bowl was totally full. So I restarted it and let it run, and watched my float bowl very slowly empty. Pump's good, lines clear, what now?
Well now you go get clean warm and dry I expect. Sorry you got doused.
Because Roadkill! Smack the stupid float bowl untill it unsticks and the float bowl rapidly fills confirming you need new parts. The float itself is wedging on its pivot or the pintle is jamming in the valve.
You can keep chasing pressure build up thru the charcoal canisters, but it's probably just a tiny scratch in a moving part.
I ordered a rebuild kit from Napa. It's already in and I've already looked at it. Guess I best get my money up and go down there and pick it up then.
Yep. Smacked it with a pipe wrench a few times and it went on up to the half. Reckon you was right. Thanks.
#25
I have another carb, but it also needs work. (more than my current) I've got another, but it goes to my '83 and has a water choke and such. Gotta rebuild all three I guess.
#26
Okay. So I rebuilt my carburetor, and the float bowl is completely filled. It runs (barely) and makes fireballs. I adjusted the float to the numbers given to me in the instructions (9.8 mm) with the little ruler that came in the kit. I had it at a *perfect* 9.8 mm. At a loss.
#27
Should be safe to tweak the float level per the FSM to get it in the middle of the glass.
but
I'm concerned about the fuel pump over pressuring the carb now. It could be the float valve ( needle ?) doesn't seat?
It's kind of progress right? Went from not enough fuel to way to much.
but
#29
I think maybe, I could try a fuel pressure regulator, or put on another one of my fuel pumps. I have a question though, there are two fuel pump types of see, one tall one, and another shorter one that looks like a flat disc. Are they different? Will go for pics.
#31
Okay so I put the other pump on. (Silver one from pic above) and paired it with a regulator. Truck works now! With a little adjustment I'll get it in the dead center of the float bowl. But then this:
This wire here filled my truck with smoke. And then it caught on fire. I'm curious as to what it does and why it caught on fire. Wondering if it has something to do with the FL like I changed recently.
On a side note, I did not take notice of how my electric choke mounted on. The wire inside is bent into a square, I assumed that the pin of the choke flap went inside of it. But there's a wire behind that square that I also have to put the pin past. Which side of that wire does it go on?
#32
This wire here filled my truck with smoke. And then it caught on fire. The two ends are where it split and it can also be seen that it damaged the white wire but did not fully melt the insulation. When it did this my dash dimmed but I think this is simply because of the power draw that the melting wire had. I'm curious as to what it does, how to fix it, and why it caught on fire. It comes out of the fuse box up with a cluster of wires, it melted further up as well but did not catch fire. Wondering if it has something to do with the FL wire I changed recently.
