Wobbly PS pulley- what's the worst that could happen??
I have a wobbly power steering pump pulley. What's the worst that could happen if I leave it. I plan on pulling it and replacing it soon, so I am asking mostly out of curiosity. I assume it isn't very good for the belt.
You could die....
Well I guess that's not the worst...
You could throw the belt and lose control and crash into a school bus stop and wipe out your best friends kids and then flip the truck and be paralyzed from the neck down so all you could do was lay in the hospital and think about why you didn't fix your stinkin truck!
You asked
But really if it's not wobbling too bad I wouldn't worry about it
mine wobbles a bit too
You asked
i agree with targetnut .mine isn't perfectly round either,but don't run into the schoolbus either.fyi I priced that pulley at the dealer and it was $90.might look in the junkyards if you aren't in a hurry.
good luck at the junkyards, I ended up getting a pump and pulley after the "deer incident" they would not sell a pulley wihtout a pump.
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
at least it is the actual p/s pump pulley. mine p/s broke on the crankshaft, try setting the engine idle with the last rib of you crank pulley at like a good 45 degree angle, its stupid trust me
83yotastockR
11
11-10-2015 06:54 AM
zombie_barbarossa
10-02-2015 10:54 PM
