Wobble in Front end
Wobble in Front end
I just had a new set of tires put on and also had the front end lined up today, its a 94 Toyota 4x4. I can still feel a wobble when going in curves say running around 60- 70 mph, Steering Stabalizer Shock, wheel bearings???? Any ideas?
Jack up the front and try to wiggle. How's that for tech help? :bounce2:
Just flex the wheels, feel for bearing play, bushing wear, check the brakes for drag, pad wear, noise, movement.... might find it helpful to try one side at a time.
And I agree with Dogman about checking the idler arm. There are plastic bushings in the housing that can be replaced cheeply and easily if you find play there.
Flying91
45
04-11-2024 04:39 PM
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
