Windshield wiper travel limits
1992 pickup with intermittent wipers, what determines the travel limits of wiper blades? Most of the time the blades go too far down and off the glass tearing up the rubber wiper. The "up sweep" travel is ok. I detect some play in arms, maybe inch or so.
Could it be a motor or relay issue?
My 87, driver's side, either hits up top or down below. The splines aren't "fine" enough to get it not to hit. No adjustment on the motor that I could find in the FSM. As Blake said find the fit that works best.
OK thanks I'll try that, but what causes the play or looseness in arms? I checked it again and there is more like 3.5 inches play up/down in both arms simultaneous. I've not fooled with wiper motor yet but suspect linkage is loose somehow.
I just shimmed it up with a couple plastic washers I cut from a bucket lid. Took almost all of the play out of it and didn't have to remove the assembly ,done it through the motor hole.
