winch with stock bumper??
is it possible to have a winch installed with a stock 2nd gen bumper? How big of winch do you need for a 2nd gen? 2000lbs? 4000? 8000??
You will not be able to mount it to the bumper itself there just isn't enough strength. You could do something like a bullbar to mount it or I mounted a receiver to my front crossmember an the winch mounts on a plate that goes into the receiver. You generally wanna get a winch that is rated for twice the weight of your truck. So for you a 8000 or 9000 should be fine.
well have a multi mount winch that a made and all i did is got one of those push bars that my 91 truck came with cut a notch in one of the tubes and then welded it back toghether like a tow hitch. got some half inch plate and cut theum to fit around the bumper and then welded them strait to the bumper. and then i got a 9500 pound mile marker winch and it has pulled a guy with a 4 runer out just fine.
ive got a line on a free 12000 winch.... and now realize id have to buy a new bumper.... now if i buy a new bumper to put the winch on, then do i have to add new torsion bars.....*sigh* the list goes on and on....
I disagree with robinhood150 - your winch selection depends on a huge number of variables.
- What kind of terrain do you expect to be winching in? Deep mud will require a higher rated winch than rocks. Search for "mire factor".
- Who do you usually 'wheel with? More often than not, your winch will be pulling the other guy. If you wheel with full-size rigs, you need a bigger winch.
- You need to consider that not all winches are created equal. One mfg's 12,000 may be the same real world pulling power as another's 8,000.
The weight of the winch and mounting will certainly pull the front of the truck down. You may be able to compensate by cranking the torsion bars, however, the ride and flex will suffer. I would recommend ball joint spacers over new torsion bars to get the best ride and flex.
Another option (and this may be the above-mentioned multi mount) is to mount the winch in a cage that slides into a receiver box (like for the trailer hitch). This would allow you to remove it for daily driving and install it just for off road, and either in the front or rear, whichever is better for the pull you are going to make.
kool.... ive allready got the BJ spacers.... i ended up trading some old tires for a 12000 lb winch... and just seeing if i actually wanna buy a new bumper and make my truck heavier. Having a winch would be more glamour then necessity.... im sure i would end up using it.
How much heavier are the ARB and TJM bumpers then stock?
do you think this bumper would look good after a good sandblast and re-paint...
http://www.4wheeler.ca/index.php?sho...3121&hl=bumper
the arb bumper is 75 pounds, the stock is about 20-25 pounds. When I put mine on with the winch it didn't make that much of a difference. I didn't need to adjust anything. I also used to have a snow plow on about 350pounds (roughly 500 pound equiv due to the canterlever effect) with no problems. I ran the plow for about 5 years.
dam celica.... i really wanna see what your truck looks like with that ARB......
did you install it yourself? cost? did you get it from national4wd? modern motors? used?
colin
colin
colin
colin
Originally Posted by Robinhood150
Warn has winch mounts that will let you keep your stock bumper...I think.
Link to thread:
https://www.yotatech.com/forums/f2/i-think-winch-would-fit-there-71005/
Celica... im working at the Bearspaw water treatment plant... are you in bowness?
i might have a line on a 12000lb winch for trading soem old tires.. need to get line and a remote...then have to buy a new bumper... not sure if i wanna spend that much.. u know
its a warn 12,000 winch.. im just worried its going to be too heavy and my mileage will suck, and suspension will suffer
what did you pay for your ARB?
Did you go in on the IFS support bar with Bill and Me?
