Wheel stand (ifs sucks)
here is a snow ones
this is my 91 4runner
http://youtube.com/watch?v=CnijjrkvPig
http://youtube.com/watch?v=r5IQVSN4Vko&feature=related
and this is my buds 89 4runner
http://youtube.com/profile?user=xbikerguy
and this other guys the mud pit
http://youtube.com/watch?v=6hxxIxRixOE
where is this? you guys are in toronto arent you?
The last couple seconds of this video shows me on the same spot, taking almost the same line to prove TC wrong in this case......
http://youtube.com/watch?v=epDk4CXvDrc
Dont you have a SAS'd rig tc?
I'll have to make another vid later this year after my SAS is done. =)
Yes, I have one of each, and depending on the situation, the SAS is NOT more stable than the IFS. Just because the wheels are on the ground, does NOT mean the situation is more stable. If the body leans over enough to get the COG outside the wheel track, you're going over - that's the laws of physics and incontrovertable.
You're going downhill, the weight is on the front. The driver's side front is going to go down just like it is now. If not, you would have held UP that tire with IFS and the rear would have stayed down.
The situation is entirely different than MarcP, who is, essentially, on level ground. (I also note that he took a different line the second time. Seth/Deathrunner showed the difference)
#26
#27
Whether IFS or SAS, it appears that they all got through and had a good time wheeling.
A lot of people seem to bash IFS rigs, but I'd rather wheel an IFS rig than sit at home. At least it's still 4wd.
#29
That should support TC's case.. That looks nearly identical to the obstacle that that I did my wheelstand on and your rig is a solid axle. I was able to get a more direct line compared to you, you're cuttin the corner sharp. I think my rig at that angle would flop over for sure. You're front is flexing more than my truck does in its wetdreams =p
#33
i was trying to take the turn wider, but gravity and super slick mud sucked me into the bug rut. i was realy close to rolling and luckely my topper hit the tree to stop it. i was able to drive right out of it though.
#34
To the original poster (drew303): Did you have your sway bar removed? That will make a pretty big difference...
Flying91
45
04-11-2024 04:39 PM
scottyg486
07-19-2015 05:34 PM
