Wheel cylinder kit has different spring
Old 09-26-2024, 04:30 PM
Jose Pena's Avatar
My wheel cylinder is rhe shorter spring on the left. The kit came with the spring on the right. Should I return these and get a matching set?
the truck is a extended cab and single rears dlx so half ton. The spring is throwing me off. I ordered another kit and the seals are correct but spring is also long version.
Old 09-27-2024, 03:23 PM
Jose Pena's Avatar
Okay guys im new to the drum brakes. I was not sure which wheel cylinder kit to get. I accidentally ordered 1 ton 7/8inch.
the outside seals were different than the ones I had.
With trial and error in learned that once I got the original wheel cylinder off. The inside seal has 15/16 thankfully I noticed and not used the 7/8inch seals since their slightly smaller.
I ordered another set from auto zone since the outside seals matched the ones i have but they were also 7/8 inch inside seals. I only need the outside seals.
why is it so complicated to find the right part.
also I think the 7/8 springs are slightly stronger.
I ordered another set that is 15/16 hope the spring is different strength. Ill get it tomorrow
Old 09-28-2024, 09:53 AM
osv
osv's Avatar
drum brakes can be a pain, it helps to take the old parts to the store if possible.
turn the drums if you can find a shop that still does it :-/ coupled with a new set of shoes it can make a difference.
larger bore i.d. wheel cylinders would be the right choice with a bigger i.d. master cylinder, for instance i used these 1" bore slave cylinders with the 1" fj80 master on my 4runner:
Amazon Amazon
for $14 it's not worth the rebuilding hassle; the smaller bores are cheaper.
The following users liked this post:
Jose Pena (09-28-2024)
Old 09-28-2024, 03:37 PM
Jose Pena's Avatar
larger bore i.d. wheel cylinders would be the right choice with a bigger i.d. master cylinder, for instance i used these 1" bore slave cylinders with the 1" fj80 master on my 4runner: https://www.amazon.com/gp/product/B000C9FXCY/
thank you for the response. At this point im so confused. Turns out that the truck has different wheel cylinders.
The left had a 7/8
The right had a 15/16
now im super confused since i dont know what it had originally.
the truck is a extra cab v6 and the front calipers are F18Q calipers.
now based on this info im leaning on getting the 15/16 cylinder.
would the bigger cylinder cause the rear brakes to grab first or the front would still grab first? @osv
phillipec94
03-08-2017 12:28 PM
805crawlin
01-30-2011 12:05 PM
Runner87
04-14-2009 09:55 PM
dezrik
09-09-2007 08:37 AM
Quick Reply: Wheel cylinder kit has different spring
