Wheel Bearings making noise
Old 10-10-2008 | 06:18 PM
AK4x4's Avatar
I have recently changed the front inside and outside wheel bearings, races, and seals on my 91 p/u a week later they began making a rubbing/grinding noise with the rotation of the wheel. Followed the Chilton's repair manual for the replacement of the bearings. What could be causing this?
Old 10-10-2008 | 06:22 PM
DeathCougar's Avatar
Have you checked your brakes? Are you sure its the wheel bearings?
Old 10-10-2008 | 06:25 PM
AK4x4's Avatar
should have mentioned that I changed the rotors and pads as well
Old 10-10-2008 | 06:27 PM
abecedarian's Avatar
if it is really the wheel bearings making noise, I'd question the installation of the bearing races.
Old 10-11-2008 | 06:18 AM
Marc's Avatar
It could be the pads dragging on the rotor.
Doesn't matter if the rotors and pads are new if the calipers are dragging.
mskalmus
05-28-2017 07:51 AM
razorman8669
07-12-2015 12:13 PM
Gamble_STi
07-07-2015 07:54 PM
skoti89
07-06-2015 07:45 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Wheel Bearings making noise
