what is wrong???
I would diagnose the problem before I started replacing parts- its always cheaper that way.
Bump... maybe someone has figured this one out already.
I just can't figure out how a 150bhp motor can jerk a 4000lbs truck forward in 4th or 5th gear.
matt, its almost like the motor completely shuts off... like it just stalls after a certain time period... mine usually did it once at about 15 minutes running, then again about an hour later... wanna see whatt it feels like, then get going about 15-20 miles per hour and drop it into 5th with it about 3 grand... your truck will buck like crazy... his problem is like that only it bucks once...
lets see,
$4 per plug = $24
plug wires - i have forgotten
02 sensor = $50
air filter = depending on what you get, $15-60
fuel filter = $20
cap and rotor ~ $20
Oil change = $15-50
someone chime in if im missing something...
and, matt, better to just do the tuneup and hope that the problem goes away because if it does, then hes got a healthy motor and no more problems... make sense?
$4 per plug = $24
02 sensor = $50
fuel filter = $20
cap and rotor ~ $20
Oil change = $15-50
#25
To have an instaneous stop/start like that sounds like an electrical issue, like you have a short somewhere. I'd start by deciding when the plug wires (particularly the ignitor to distributor wire) were replaced & inspect the distributor REALLY WELL.
zytra
01-24-2019 03:16 PM
primordialbeast117
12-19-2015 12:23 PM
charlie_fong
09-27-2015 10:06 PM
