What Toyota TBs are larger then the 3.0 one?
I measured the TB of my 3vze today and I cam up with 53mm once you account for the plate/rod at WOT.
I want to find something that is closer to 70mm, is there one from a lexus or a supra that is closer to that size? Maybe even the one from the 3vzfe?
I guess I could use any junkyard TB that has a TPS that can be wired into the stock harness. Not sure what ones would work but I know the mustang is 65mm. Are other manufacturer's TPS's compatable with a Toyota ECU?
