What is this part?
1 Post
What is this part?
3VZ-E engine. Driver side under exhaust manifold. Leaks oil like Valdez.
What is the blasted part?
What does it do?
Is it replaceable?
Thank you
Dutch
Layin under the driver door,looking up and forward.
Layin under front bumper lookin up and back.
What does it do?
Is it replaceable?
Thank you
Dutch
This is your oil cooler. If it is leaking Anti Freeze, then your hoses are bad (the hoses go to the block and the water pump). If it is leaking oil, the bolt gasket or o-ring may be bad. Pretty easy fix if you can get to the oil cooler. Just undo the bolt, and replace the gasket.
Hope this helps.
Hope this helps.
i just did mine while the engine was out of the truck (had to do a rebuild), but i am guessing that you may be able to access that by taking off the left tire. If not, it is just the bolt in the center of the cooler, you pic looks like you have easy access to that.
GFL my friend.
GFL my friend.
Toyota has the o-rings...the parts stores do not..I had the same issue..there are three o-rings in the set..run you about 12 bucks..not too bad..but it is an expensive set of rubber o-rings!
I just did it w/ the engine in the bay...but I have a 3" BL. Not the worst job in the world, but I could not find the parts at NAPA or carquest, so I found them at http://www.trademotion.com/partlocat...?siteid=214074
If you enter your VIN here, they guarantee the right parts.
OEM Catalog
WASHER, SEAL 1 $3.11 $0.00 $3.11
Status: Sent
OEM Catalog
GASKET, OIL COOLER 1 $0.84 $0.00 $0.84
Status: Sent
OEM Catalog
RING, O 1 $3.76 $0.00 $3.76
Status: Sent
Sub Total $7.71
Tax $0.00
Shipping $6.00
Handling Fee $0.00
Total $13.71
You need the 3 gaskets shown at the bottom here. Enter your VIN to be positive on the part number.
http://www.toyodiy.com/parts/p_U_199...MGEA_1503.html
OEM Catalog
Status: Sent
OEM Catalog
Status: Sent
OEM Catalog
Status: Sent
Sub Total $7.71
Tax $0.00
Shipping $6.00
Handling Fee $0.00
Total $13.71
FS[GreatLakes]: 22RE performance and stock parts (pic heavy)
05-20-2016 10:27 AM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
