What glue to stick this floor mat back down?
Floor mat came off the drivers side on my '94 4runner. Any idea how to stick this back down? What glue should I use? Should I clean the old glue off somehow first? Is a new floor mat recommended?
Mine was coming loose. I cleaned the rubber real well, and used Gorilla Glue to stick it down. Sprayed a little water on the carpet, ran a thin line of the glue around the rubber, and stuck it down. I put a weight on it to hold it in place while the glue set. About 2 hours, IIRC.
It's been holding beautifully so far...
Pat☺
Pat☺
