what gear oil to use 80/90 ?
so I’m a little confuse
so I want to run 8090 weight gear oil in my rear differential in a 1990 22 re 2wd
so what do I use Limited slip or hypoy c ?
and what is the difference between the two?
let me know
thanks
let me know
thanks
This is an old thread, but I have a similar question. I have some new and old bottles of Castrol 80w90 gear oil. Both are GL-5 but the new bottles say limited slip and the old bottles say hypoy C. Is there any significant difference and can I mix the two types?
If it were me, I would NOT mix the two types.
I personally, if it were me, again, would use the Hypoid version. That's just my opinion, for what it's worth. As long as it's GL-5. THAT'S what matters most, but I don't know what effect mixing the two different types would have.
Of course, on the other hand, the newer the better, but I believe, as long as they been in the factory sealed bottles, it won't matter. I may well be wrong on that, though.
Good luck, whatever you choose.
Pat
Pat
Pat
Pat
mkgarrison5
41
03-18-2018 08:27 AM
4RunnerFever
10-14-2007 03:02 PM
blakjak
07-23-2006 06:54 PM
