What do i need to check? Fuse, wireing harness, etc
Nephew hooked up the battery terminals wrong and now truck wont start. it'll crank but not fire. where do I start? we've replaced several fuses but still no luck.
See my signature.
Start with basics.
Got spark? Got fuel pressure? Hear, feel fuel pump run when you put IGN switch in "Start" position?
Did you verify that fuses were bad and that replacing them will fix the problem?
Got a multimeter?
Start with basics.
Got a multimeter?
Start by telling us what you are working on, like RAD4Runner said, then continue by getting a voltmeter and a test light. You probably have a blown fusible link, so check for power to your fuses with the key on and see what is getting power and what isn't.
atcfixer
30
03-15-2024 06:26 AM
egesledder
All Other Toyota Swaps
120
02-22-2017 06:14 AM
Rock Slide
30
09-12-2008 07:45 AM
