What is the difference between these??
They're oil pressure sending units. If I remember correctly the one on the left is for a full variable gauge and the one on the right is for a dummy light.
I just took the cluster and sending unit out of an auto 95 4runner 4wd v6 and that's the sending unit it had..
I swapped both over to my manual 93 pickup 4wd 22re, plugged in my connector to the 4runner sending unit and the gauge seems to be working correctly...
The left is a factory style sending unit, the right is not a factory style (but still probably a sending unit, you can tell the two apart typically by size of the diaphragm) maybe not even Toyota I don't recognize the plug but I've certainly not seen them all.
A "sending unit" implies a variable resistance output, not to be confused with a "switch" which is either open or closed.
YT Community Team
They’re both sending units for a oil pressure gauge, not a light. The one on the right is for slightly newer vehicles. Probably the only difference is just a more positive lock of the connector.
dirtoyboy
06-25-2008 11:37 AM
