Went wheelin'... now the truck won't start
So, yesterday, after I got done havin some fun in the woods with my buddies, my truck wouldn't start. Kinda messing around with the positive battery cable will get it to start. I'm fairly sure its something electrical, any ideas? My first thoughts were that it was a bad ground or connection somewhere. Any help is greatly appreciated
Clean both battery terminals,
Check the tightness of the pos. battery cable on the solenoid,
You may even want to remove the starter and have a look-see at the solenoid, may need some attention in there.
I went through one pretty serious mudhole a couple times, the rest was just trail-riding and such. I think that I just jarred a battery cable loose or something. Seeing as this problem as never occured with my truck before, I figured I'd ask around and see if there was anything wierd with 3-liters that may explain this.
I went through a muddy water pit and the next day my truck didnt want to start either, whacked the starter couple times and it started right up.....and still starts right up!
