weird problem
Old 11-25-2008, 01:35 PM
DudeBud's Avatar
Originally Posted by DeathCougar
When you find the wiring harness connectors, you could just pin the connectors out, then you wouldn't have to cut and splice
that's exactly what i had planned if the pins are the same. you don't have a 89-95 harness laying around do you?
Old 11-25-2008, 02:45 PM
Staff
DeathCougar's Avatar
Alas, i have nothing in stock that I can cut plugs off of. If i get a core back any time soon, i can PM you but I don't know when that may be.
Old 11-25-2008, 02:52 PM
DudeBud's Avatar
I'd appreciate it.
Old 11-25-2008, 05:15 PM
abecedarian's Avatar
another thing to consider is the impedance of the injectors.
there are two basic types of injectors, low impedance and high impedance, a.k.a. "peak and hold" and "saturated", respectively. a "peak and hold" ECU can power "saturated" injectors, but not the other-way-'round. mixing or using the wrong injector type can fry the ecu, thus the different plugs on the injectors and harness to prevent the wrong one being installed.
measure the resistance across the terminals in your fuel injectors and make sure you get new injectors with the same resistance. that doesn't mean you won't still have a problem with them, but it dramatically reduces the likelyhood of a problem.
Old 11-26-2008, 05:21 AM
  #25
DudeBud's Avatar
ade... i was pondering that too at work today.. so i think I'm jut going to get a set of 88 injectors.
Jonny246
07-24-2015 12:37 PM
yourrealdad
07-21-2015 11:13 AM
kyletbert
07-17-2015 11:39 AM
icentropy
07-14-2015 10:23 AM
jon.r
07-11-2015 03:34 PM
Quick Reply: weird problem
