Weird Door Lock Issue
Not sure if this has been posted before but if I accidentally try and open the driver door while it is still locked I can not pull up on the manual lock knob. I have to put the window down and pull on the handle from the outside, this "resets" the lock knob and then I can pull on the knob.
The following 2 users liked this post by Paul22RE:
BigBluePile (03-30-2021),
Jimkola (03-31-2021)
Take the interior door card off and you can probly see which linkage is binding. Hit all the joints with a graphite lube or lithium grease. Maybe one of the plastic clips broke...
Yeah, probably the plastic clip. A small zip-tie would work in a pinch or just buy a new clip.
