Water in intake. How screwed am I?
Old 02-17-2016 | 02:17 PM
ladybugRC's Avatar
Adding coolant for the first time on my fresh rebuild. Pressurizing the system and realized that my intake is completely full of coolant. I mean really full:
I'm trying to siphon out the coolant with some vacuum line I have.
How the heck did this happen? I've checked and rechecked all my hoses- all new, new head, resurfaced intake- the water is coming in through this hose:
And this hose:
Both are where they should be. On the bottom side of the intake they're both connected to the assembly at the front of the lower intake where the sensors are.
What did I miss!?
And now there's water sitting in the chamber? In the oil pan? How screwed am I?
Thanks in advance for your help!
Joe
Old 02-17-2016 | 02:28 PM
ladybugRC's Avatar
Found the problem. I am retarded. Crap.
Am I still screwed? Will this ruin my brand new motor if I don't take it all apart and clean it??
Old 02-17-2016 | 02:57 PM
ladybugRC's Avatar
Yes, the chambers are full of water. I removed the spark plug from #3 and out poured coolant...
Old 02-17-2016 | 03:27 PM
ladybugRC's Avatar
Had a coolant line and a vacuum line reversed. Pressurized coolant into all the vacuum lines. I am so upset.
Old 02-17-2016 | 03:55 PM
wyoming9's Avatar
Red face
Just hope you did not get any in the oil .
I would drain that oil just to be safe.
Antifreeze takes out the bearings in a heartbeat.
92ehatch's Avatar
Looks like you found that the aux air valve lines were hooked wrong.
Just vacuum or compresses air the coolant out. Will be fine. No damage done If you didn't start it.
Change oil
Old 02-17-2016 | 05:36 PM
ladybugRC's Avatar
Thanks guys.
I realize that I probably should have not started a new thread for this- just showing some frustration.
If you're interested, follow this on my build thread:
https://www.yotatech.com/forums/f199...l#post52309841
Joe
Old 02-18-2016 | 05:50 AM
Terrys87's Avatar
Staff
As long as you got all of the water out of the engine, you should be ok. I would just keep an eye on things for a while.
Rattlesnake
01-24-2016 06:01 PM
hbom
01-24-2016 09:33 AM
noahstancik
01-22-2016 11:34 PM
d-wood
01-21-2016 07:11 AM
d-wood
01-20-2016 12:16 PM
