Old 03-11-2016, 03:06 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical Guides
Print Wikipost
Volt meter goes too high should I worry?
Old 01-13-2015 | 06:40 PM
RJR's Avatar
RJR
The meter in my SR5 cluster reads about like yours. I put a real voltmeter on the bus and it reads 13.8 volts, which is right on. So, as has been said, don't trust the gauge cluster, measure it with a handheld meter.
Old 01-13-2015 | 07:07 PM
jaysson_2012's Avatar
Thanks for the input, I'll take to O'Reilly and have them check it for free.99!
Old 01-13-2015 | 10:14 PM
RAD4Runner's Avatar
+ 1 for using good volt-meter, not dash volt-meter.
From FSM (22R-Eliable):
With engine from idle to 2000 RPM, Voltages at B should be:
13.9 to 15.1 V @25°C (77°F)
13.5 - 14.3V @115°C (239°F)
Temp is probably engine compartment temp.
Old 01-14-2015 | 07:18 AM
scope103's Avatar
Or you could just get your own multimeter, and save the gas used driving to O'Reilly's. http://www.harborfreight.com/7-funct...ter-98025.html
It's a tool you really should have if you ever work on your truck, and for the money?
Old 01-14-2015 | 07:52 AM
  #25
RAD4Runner's Avatar
+++++1
AND you learn more about your truck, rather than relying on others.
Someone on the forums once said that having others work on your truck is like having someone work on your girl and and paying them for it - LOL!
Old 01-14-2015 | 02:31 PM
  #26
I actually already have one of those multimeters its incredibly unsteady and inaccurate. I would rather have O'Reilly check it for free. Besides, I drive by 2 advance autos, 2 autozones and 1 O'Reilly all on my way to work, so its no struggle
Someone stole my nice fluke multimeter a couple years back!
Thanks for all the input though! I have tomorrow off work, gonna have to go to the parts store anyways so I can get some fuel line for my FPR!
Old 01-14-2015 | 04:30 PM
  #27
RAD4Runner's Avatar
Still better than the stinking stock dash volt-meter.
I use
this this
for monitoring battery voltage while driving when I could not be probing test points. Enough accuracy for troublehooting. Someday, I'll wire a volt-meter directly to Alt "B" post.
I have a HF volt-meter for rough and tumle application in the truck, while my nice Fluke stays at home.
SubiKing
08-21-2021 03:57 AM
RatOmeter
10-22-2015 03:17 PM
Sarcazmo
08-15-2015 08:22 PM
JHalcyonM
08-04-2015 01:19 PM
80Truck
07-24-2015 03:12 PM
Quick Reply: Volt meter goes too high should I worry?
