Video: Does this seem like fuel starvation?
Old 04-01-2012, 02:48 PM
combatcarl's Avatar
That plug on the right looks like it took some aluminum with it when it came out...was that the #1? (If I'd read, yeah it is) How did the new plug thread in? It may spit it out eventually if your threads are buggered...
Old 04-01-2012, 03:17 PM
Mandy Tuning's Avatar
I won the bet ignition problem lol
Old 04-01-2012, 06:23 PM
jska's Avatar
It was the #1. And yeah -- I figured that was aluminum or some sort of compound the PO put on the plug when installing it.
The new one threaded in nice and tight. I used one of the nicer older plugs to clean the threads a few time before installing it.
I'll keep an eye on it.
Side note -- When installing #4, the ceramic coating cracked a little because for a split second I wasn't wrenching completely straight on because of the awkward location of that cylinder. It should be replaced, correct?
jska's Avatar
Old 04-01-2012, 06:35 PM
  #25
combatcarl's Avatar
Well if it threaded in nice, it should be fine. Little copper antiseize will make it easier next time around. The hi-temp stuff. And the cracked one should probably be replaced before long.
Old 04-01-2012, 06:37 PM
  #26
jska's Avatar
NGK specifically states not to use anti-seize with their plugs, so I followed their advice.
Old 04-01-2012, 09:30 PM
  #27
combatcarl's Avatar
Ha! Really? I never caught that, just always put a little dot at the start of the threads and put 'em in. Really should read the box, then, huh?
bigjstang
08-25-2021 12:41 AM
JNapolitano
11-14-2019 07:46 PM
wafoogalla
11-02-2016 11:02 AM
Hiluxtrucha
07-22-2015 10:00 AM
Fundy Rider
07-16-2015 01:35 AM
Quick Reply: Video: Does this seem like fuel starvation?
