Valve sticking
The ding on the piston does not look severe enough to be worth replacing the piston over. One might want to debur any sharp edges at the ding. The valve that got tagged is another matter. The head of the valve is likely bent enough to prevent a good seal and should be replaced.
I agree that the valve stem seal was off the guide, but I don't see this being the cause of the valve piston interference. You need to understand the cause of the problem and correct it.
Eugene
Eugene
foampile
12-18-2022 01:29 PM
