Upper Radiator Hose
Upper Radiator Hose
OMW in to work this A.M. my upper radiator hose failed. Has about a 1 3/4 - 2 inch rupture in it. No big deal there, i got a ride to a parts store that was close by and replaced it and radiator fluid. After starting the truck and driving a few min. the idle started acting funny.... revving to 12-1300. that leveled out after about 1-2 min. then my oil pressure gauge was a bit high (a little above half ) and my idle was high around 2k. Temp gauge went up to were it is normally, then completly bottomed out. When it came back up the idle dropped to 1k and oil psi. to 1/4 ... everything was as it should be and still is..... Does anyone have any idea WHAT THE HELL was going on? lol Thanks in advance.
right, i got that. My question was WHAT would make my temp gauge bottom out.. and the answer was air... got that. At the SAME time, when temp dropped, OIL PRESSURE became normal AND RPMs dropped to normal. WHAT is the correlation?
Coolant flows throught the throttle body if I am not mistaken. As the air pocket works its way through the TB, the TB temperature would increase disproportionately, which could cause an erratic idle, and the idle would then impact oil pressure. This is my guess, but I will defer to the experts.
The idle RPM is controlled by a bi-metallic spring that is heated by engine coolant. Sounds like it was just a coincidence that warm coolant hit the IAC (which lowered your idle and oil press) at the same time that an air pocket hit the water jacket your temp sensor is screwed into, making the gauge bottom out.
If everything is normal now, it sounds like it was all just because of the air bubble. Make sure you check your system and make sure the coolant level is topped off.
Also, do the burping procedure we talked about in PM.
the1998sr5
15
07-14-2020 08:35 PM
JaredL
03-28-2016 09:08 PM
Poncho0206
07-10-2015 06:21 PM
