u bolt flip kit shock questions
#25
Ya this one http://www.sky-manufacturing.com/new...uct.php?id=131
You don't think 14" would be required do you? I have maybe 3-4 in suspension.
#26
The best way to determine what lenght of shock you need is to jack up one side untill the spring are totally flexed out and measure. You shock should not be the limiting factor in either compression or extension.
#27
^^^ been thinking about the same thing. I was just going to take a piece of 2" square tube and put a few nuts on it to give me some different options. And now looking at the hoop design i don't see why i couldn't just slice and weld a square tube hoop, i figure if i have to weld in a shock hoop anyhow, why not put a few more options in...just thinking outloud.
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
DrZero
18
07-24-2015 11:31 PM
