Truck won't start now??
Old 04-29-2008, 01:46 PM
Team420's Avatar
Thanks.. I already did the test and everything was in spec except the resistance between e2 and vs terminals, it would flash about 20 ohms and then read open loop, i tracked it down to this little thing in the afm
and goes in here under all this
into this hole
Old 04-29-2008, 01:49 PM
Team420's Avatar
any idea what it is, and if i can fix/replace cheaply...everything else works fine.
Sorry for the crappy pics, had to use my phone cause my g/f lost my camera in a river...lol...been a "bad luck" week!!
Old 04-29-2008, 02:03 PM
mt_goat's Avatar
Oh my, I'm really starting to feel for you dude. Please don't say you lost your girl too.
Good luck finding small parts like that, I bet Toyota just sells that AFM as an assembly. I have no idea what that is.
BTW you took the screws out didn't you?
Old 04-29-2008, 02:18 PM
Team420's Avatar
haha No...my girl still loves me...she's the best...yeah i did take the screws out...after i did the test, and knew it was junk anyway... if i can get a new one of that part, i am sure ill be able to fix it tho...its really not a very complicated sensor.
Old 04-29-2008, 02:42 PM
  #25
mt_goat's Avatar
You should be able to find a junk yard AFM or try one of the guys parting out an engine in the classified section.
https://www.yotatech.com/forums/f91/
http://www.car-part.com/
Old 04-29-2008, 02:49 PM
  #26
Team420's Avatar
yeah, I have a donor truck ive been buying parts from at a local yard, think im gonna offer him $400 for the whole thing...he already said $550, delivered, so maybe i get it cheaper if i pick it up.. either way...i posted that to see if anyone knew what it was, and if i could buy it cheap( i know those are high expectations, but you never know!)
Old 04-29-2008, 03:19 PM
  #27
Team420's Avatar
Another quick question... it seems kinda weird to me that the truck has run(extremely rich) for over 5 min, with the fuel pump unhooked... even while giving it some throttle...usually it dies after about 10-25 seconds after i unhook it...where might the fuel be coming from? was there really that much left in the chamber? Cold start injector maybe?
thanks
Old 04-29-2008, 05:54 PM
  #28
iamsuperbleeder's Avatar
Unhooking? As in unplugging the power from it? It should die almost instantly because the pressure will drop to nothing. Are you sure you're unplugging the power to the pump and not the one to the sending unit?
Also, if I'm not mistaken, that little booger you pulled out of the AFM that's full of, well, crap for lack of a better word, is the air temp sensor. Unfortunately, I don't believe you can purchase them separately, only because it's built into the AFM which is considered non-serviceable. If you sweet talk the guys at the stealership, then maybe, but very unlikely, lol.
I've filled two of these things full of muddy water and replaced both because that little thing got clogged, I tried to clean it, and I ended up breaking it...
Just one more though; here's what I personally would do. Look on eBay, not for the AFM, but for other used parts off a truck similar with close year and same motor size, then ask the seller if he has one. That's how I got both of mine for about $30 a piece!
Old 04-30-2008, 04:12 AM
  #29
Team420's Avatar
^ thanks for the tip...yeah, i figured out it was the air temp sensor, by the code 24 im now getting( at least now my ecm is working properly) and am going to get a whole new air box with hoses and afm today($15..wooohooo). I'm pretty sure i unplugged the fuel pump(little hole under rear pass. seat) and in the past when servicing fuel system, the same plug worked for me, if it was just the sending unit, my fuel guage wouldnt work right? i'm thinking maybe pressure in the tank is pushing the fuel through? running out of ideas!!
Old 04-30-2008, 04:14 AM
  #30
Team420's Avatar
also, I did notice last time, even though the truck died with it unplugged, the cold start injector still had pressure (it sprayed gas all over the place) but the truck was also warm at that point...dunno if it makes a difference or not.
Old 04-30-2008, 09:01 AM
  #31
Well the cold start injector's feed line branches right off the rail for the main injectors, so if it still had pressure, the hole system does, but it shouldn't keep spraying for more than a few seconds, especially if the truck's warmed up...
I'd start off throwing that new AFM in and see where it stands. Good find for $15 btw!
Old 04-30-2008, 01:04 PM
  #32
Team420's Avatar
so put the afm in, and still runs the same...started out great, then 5 sec into it...back rough/low idle, and stalls at WOT, or even 1/2 for that matter...but still running, even tho fuel pump has no power???? maybe ecm is junk?
Old 04-30-2008, 01:06 PM
  #33
Team420's Avatar
yeah, i know where the cs line comes from...just drawing straws at this point?
Old 04-30-2008, 01:24 PM
  #34
Team420's Avatar
reconnected fuel, and wont start, disconnected again, and after a few cranks, she fired up...same...where is all this extra fuel coming from? could my coil not be putting out enough juice? igniter maybe? back to the forums to do more searching...
Old 04-30-2008, 03:32 PM
  #35
Team420's Avatar
Now I'm getting code 53...this means my ecu is no good right? could it just be a bad ground...never encountered this before
Crazychris1871
06-27-2016 10:38 AM
Cesarl74
04-23-2016 06:07 PM
newzingo
06-24-2015 01:50 PM
slider417
06-22-2015 10:18 AM
Corey
06-10-2002 04:23 AM
Quick Reply: Truck won't start now??
