Truck died all of a sudden and i have no idea why
Old 10-06-2009, 04:08 PM
90-3vzeslug's Avatar
check the pickup in the distributor while you've got ur testing hat on!!!!!! it could save you alot of agrivation and $$$$$
Old 10-07-2009, 11:24 AM
demolishionc4's Avatar
ok well it runs fine now but when i cut it off after a few mins, id dosent want to start back up, itll like sputter for a sec and then nothin.... just the sound of it cranking... i think its the filter so im goin to replace that now
Old 10-07-2009, 01:29 PM
ok so it runs kinda good but it still sputters and the gauge is still jumpin but not as bad... and i replaced the filter and i know the pump is good cause the dam fuel was spraying on me... o and when the truck is running if i turn on the fan or the headlight the engine will just about die and thats from like 1500 rpms.
Old 10-07-2009, 01:50 PM
bigt's Avatar
ignitor/coil assembly MY 22RE did this last year!
Old 10-07-2009, 07:57 PM
  #25
so i should replace my ignitor since i just replaced my coil, is there possibly a cheap fix for it?
Old 10-10-2009, 09:55 AM
  #26
ok so i was gonna try wiring in a dr 124 ignition module and befor i started i was testin the voltage in all the wires and i was gettin about 9 somethin.... isnt that bad?
Old 11-12-2009, 11:33 AM
  #27
ok i havent got a new ignition module yet cause there so dam expensive but i got a video on what the truck is doin, it starts to jump towards the end though, watch the tachometer
http://vids.myspace.com/index.cfm?fu...eoid=100583625
91toybeater
12-27-2015 07:46 PM
puffin04
07-10-2015 09:17 PM
ibayne
06-26-2015 06:30 AM
tpg013
06-27-2002 02:16 PM
Quick Reply: Truck died all of a sudden and i have no idea why
