troubles removing the freewheel hub. 94 4runner
I'm trying to replace my cv axels and having troubles removing my freewheel hubs. I believe I have ADD hubs. Chiltons and on-line mannuals only cover manual or drum brake hubs.
I've removed the 6 cv to diferential bolts. Removed the freehub bolts and washers. Freed the freehub body however, the feehub will not come off. It will only slide off about 1cm then stops. What next?
