trouble starting
trouble starting
does anybody elses 3.0 take 10 seconds to start? it will sputter when i crank it and then slowly and weakly it will start. how can i fix this problem?
thanks in advanc
thanks in advanc
Hey from Austin.
My first guess is that the fuel system is losing pressure. There are two terminals on the diagnostic block you can jumper to get the fuel pump to run before the car has started. (Search for it in these forums.) If you jumper it and then it starts immediately, you know you've either got a fuel leak to the outside (which you could smell), or else your fuel pressure regulator is leaking fuel back to the tank. And it's a cheap and easy diagnostic, it'll cost you a paper clip.
Don't forget to post back with the results!
i havent gotten a chance to try it but when the key is in the on position i hear a click noise from the rear abs and then a couple seconds later i hear the fuel pump running so i think its just kickin in late.
Prob. not the fuel pump you're hearing, if you mean the car's not running when you hear it. The fuel pump is switched on in the AFM, which needs to be open a minimal amount (i.e. car is running) before the contacts close.
My truck makes a whirring noise from the rear ABS for a moment after turning the ign. on. That's in the front though; fuel pump is in back.
Avenged
07-09-2015 07:55 AM
