Trevor's 2wd hill climb!
his is 2wd, yours is 4wd... i hope yours is better with another two drive wheels and a low range
or maybe just sling a strap around her and let her PULL you up that hill, lmfao
I mean hey, if you had a winch, she would make a GREAT anchor point
pretty sure i never said i USED my 4wd...........in fact im positive i didnt...for something like that i dont have to put it in 4wd...or low range..
obviously my truck in 4wd will be more capable than his truck even if he does have a locker....
#26
Yes I have a locker. It doesn't help a lot...other than when I am in situations where one tire is way off the ground, or I am pulling out of a boat ramp. I've thought many times about doing a 4wd swap...not going to happen.
I will inherit and 4wd one day
#27
Btw - it doesn't look bad at all in the vid. I took pics but they didn't turn out. Basically i'm pretty sure my truck wouldn't make it even if I had 2k pounds in the bed...because they are pretty big ruts, and I think I bottomed out at the end of the vid...also it was already slanted uphill to begin with. I "can" make a better vid this weekend. But my poor 2wd will only take me so far
#31
Props to you man...give er hell!!! Just have fun with it and when you have some extra cash burning a hole in your pocket grab another this time with 4wd so then you'll have a pair.
#32
#34
Dale Johnston
11
10-31-2015 10:22 PM
kbpickens
10-02-2015 03:37 PM
Cycles
09-29-2015 06:37 AM
