Tranny over-reving
Teuf,how much did it cost you for a new clutch? if u dont mind me asking.Betelnut I only reved it for about a total of 10 seconds total.I was able to maintain 65mph but it wouldnt let me increase my speed.Evil dingo,sounds expensive for those seals and I dont have the means to work on my 4Runner.I would have to pay a pro to do it.
Whoa, only $50/hour? NICE!!! The folks here in Austin cost at least twice that.
For $50/hour, I might stop doing the work myself and take it in!
Whenever I get a new vehicle, I always spend several sessions fixing what the last mechanic screwed up. Actually, the Toyota hasn't been bad so far....
#26
If you've never done a clutch job before, I recommend trying it. It's a little daunting, with a bunch of heavy lifting, but it's by no means hard. Remove the drive shafts, and shifters, unbolt the bellhousing from the engine, stick jack under transmission, unbolt transmission crossmember, pull transmission back off of engine, and lower. I recommend doing it over a weekend with a friend, but you CAN do it by yourself (it's hard though). Seriously, it's a great project to get yourself dirty with. It's more of a "Move stuff around, and it will work out fine" sort of job rather than a "I better do this perfectly or I'll blow up my motor" sort of job.
I ran a Centerforce dual friction in my Supra for a season, and I was impressed with it. It handled abuse at the strip better than anything I've driven, and still engaged stock like. It wore a little too quick for my tastes, but that's due to my driving habits more than the clutch. The DF has one face of organic compound and another of ceramic, giving you the best of both worlds. As for a heavier flywheel, could someone explain to me why this would benefit a dd/offroading truck?
#28
Go 25-35, put it in 5th gear, and stomp it. If she revs, your clutch is bad.
Clutch job is a piece of cake in these rigs. I'm sure a do-it-yourselfer could handle it with the right tools
#29
Thanks for all the input guys.Looks like a Marlin clutch + a stock flywheel(per Gnarls).Where I live right now is a no-go on doing it myself.Interestingly enough today I drove my *ss off and the clutch/tranny did great but Im getting it checked out regardless.I will look into the clutch pedal adjustment.I hope its something simple,I was planning on buying some Duratracs next week.My tires have some tread but are dry rotting.Thanks everyone!
#30
@teuf
Now I know I'm a little skewed by being a mechanic now for a decade, but if you tackled a Headgasket, which has a lot of intricate parts to reassemble , why not do a clutch job? There isn't anything complex there. Just heavy components. Drop the drive shafts, drop the cross member, split the trans and transfer if it's too heavy as one piece, remove trans, remove clutch, reassemble.
There are no settings to swapping out a clutch, no timing to redo, no tolerances to really be concerned about. Just torque the pressure plate to spec and the rest can be blasted together with an impact gun... well except for the driveshafts impact guns don't fit very well.
#31
MMMM well at the time (91) my studio / Garage was tied up with photo eguip and setup, It was worth having stealership do it, as much as i hated to go that rout i did.
TheBFA
02-15-2020 06:55 AM
live4soccer7
05-11-2016 06:52 PM
hiluxinargentina
09-30-2015 05:51 PM
