TPS removal
Old 03-19-2011, 06:22 AM
  #41
93YotaGuy's Avatar
did you ever figure this out? It seems like all of the TPS trouble threads never get fully resolved.
Old 03-19-2011, 08:08 AM
  #42
BigSwole's Avatar
Hey bud. I did get the tps set right I'm assuming. I kept getting the code 51 tho. But the cel never came on so I'm guessing it wasn't a problem.
It is a real pain to get to. I would suggest removing the intake to do it or the water neck thing.
It takes a lot of patience to get done. Alligator clips are a must though.
Email me if u need fast response with some help
Old 03-19-2011, 08:15 AM
  #43
4Crawler's Avatar
You can swap in some Allen head screws to make it easier to adjust the TPS in place:
- http://www.4crawler.com/4x4/CheapTri...llenHeadScrews
With a ball end Allen wrench you can get to both screws with out issues, unlike the factory Phillips head screws.
Old 03-19-2011, 09:23 AM
  #44
peckinpah's Avatar
I used pieces of vacuum hose to hold the ohm tester sensors on. I also swapped out the screws with allen bolts. The job would not have been possible had I not done these two things.
When my TPS went bad, it was easy to diagnose. When I took it off and hooked up the ohm tester sensors, the readings kept jumping around like crazy. I'm not sure if every bad TPS does this but mine sure did.
Old 03-08-2012, 05:11 PM
  #45
mpwarfy's Avatar
Originally Posted by thook
You could pull the thermostat housing off, but then you have to mess with coolant and resealing the housing
Ok now I feel like a idiot... I had to pull mine the other day and I didn't notice any type of gasket so I put it back the same way. what do you reseal it with?
Old 03-08-2012, 05:16 PM
  #46
mpwarfy's Avatar
X2
I'm having a similar problem I did test my AFM and it failed static test 3 from 4crawler's site but i just get code 51 which as far as I know has nothing to do with the AFM. Im sick of getting the finger on the interstate.
Old 03-08-2012, 05:22 PM
  #47
4Crawler's Avatar
That is sealed with the o-ring surrounding the t-stat. I've reused that gasket as long as it is not split or permanently flattened with age.
Old 03-08-2012, 05:35 PM
  #48
4Crawler's Avatar
X2
Check out the possible causes of code 51 below:
- http://www.4crawler.com/4x4/CheapTri...shtml#Late22RE
Old 03-08-2012, 05:55 PM
  #49
mpwarfy's Avatar
haha ok then i sealed it! thank you
Old 03-08-2012, 06:18 PM
  #50
mpwarfy's Avatar
this may be stupid but I never use the A/C I know the AfM is no good because it didnt pass the test on your site but I don't get the code for that anymore (AFM) could this code 51 be from my faulty Afm? im just wondering if its possible... p.s. I LOVE your website
Old 04-04-2012, 01:16 AM
  #51
MGM719's Avatar
I know this thread is old, but this might help someone with the Code 51. My solution for my Code 51 on my truck was the Neutral Safety Switch. My truck idled fine, but would throw the code 51 so I didn't think it was the TPS. One of the teeth on the male side of the Neutral Safety Switch connector had broken off, so I rigged a new one and problem solved, no more Code 51. My reverse lights never worked since I bought the truck and now they do.
SUGGESTION: If your truck throws a Code 51 but Idles just fine, and your reverse lights don't work, then your problem is probably like mine and the Neutral Safety Switch is not functioning right.
Gone Fission
01-12-2023 10:34 AM
Blamalam
03-12-2022 07:34 AM
accuracy
08-30-2015 09:47 PM
Blamalam
08-16-2015 12:29 PM
Sidherish
08-03-2015 07:17 PM
Quick Reply: TPS removal
