TPS part number change from toyota/installation troubles...
I have an 89 truck, 4x4, 22RE with a bad TPS. The last digits of my original TPS are 28030. THe dealer said the number has changed now to 20050. I've tried this part but it doesn't install correctly. When it is installed and fully adjusted in the closed direction the throttle is still open considerably. Also, the throttle stop screw cannot be adjust to come in contact with the stop.
has anybody else had this trouble or am I just doing something incredibly stupid?
Any help is appreciated, I'm fully frustrated over this stupid thing.
Originally Posted by TNRabbit
Do you have it on backward? (180 degrees opposite?)
No, it's not on backwards, same way as it came off.
Originally Posted by superjoe83
make sure the "tangs" of the TPS are on the correct side of the "tangs" on the throttle shaft, sounds to me that they are not
Vargntucson
07-04-2015 12:15 PM
