Toyota re22 1996 injectors dont open
Old 10-14-2024 | 11:09 AM
melonlyktan's Avatar
Exclamation Toyota re22 1996 injectors dont open
I got a Toyota re22 from 1996 that injectors dont open. I have measure the electric signal to the injectors and it has constant signal (6V) and no pulse.
I have replaced the Circuit Opening Relay and the air flow meter. I have good presure on the fuel rail. The ECU is cleaned and tested by someone professional.
I have also done the diagnostics and got the trouble code that says its the air flow meter and I have changed it.
Thank you for any help
Old 10-14-2024 | 06:31 PM
osv's Avatar
osv
see if this thread helps:
https://www.yotatech.com/forums/f123...needed-221468/
camel854runner
10
12-11-2014 06:15 PM
ahickman
03-21-2009 08:12 PM
spdjnky
10-08-2007 09:35 AM
rimpainter.com
10-16-2006 04:51 AM
sstockton
03-02-2006 08:07 PM
Quick Reply: Toyota re22 1996 injectors dont open
